I am working with Grafana v10.1.10 + Mimir backend
I want to be able to “split” a big tenant into mutiple smaller.
I will face in a near futur and volumetry issue and to avoid that I want to re organize my timeseries into smaller tenant.
Thing is I want to keep my timeseries so basicaly rewritte the past in new tenant and then writte current in new tenant.
For now I do not know the best way (more efficient) to do it ?
Is is with query + remotre writte ?
Using promtool to create block ? Seems bad because in my experience it takes so much time to build block.
Perhaps they are other ways to do it ?
Thx for any feed back.
