When querying a log file in Loki that was ingested by promtail with a defined timestamp, the resulting output is zero rows. I’m not sure why.
Promtail config:
scrape_configs:
- job_name: testjob
pipeline_stages:
- regex:
expression: '^(?s)(?P<time>\S+?)\s+(?P<ip>\S+?)\s+(?P<content>.*?)+$'
- timestamp:
source: time
format: Unix
static_configs:
- targets:
- localhost
labels:
job: testjob
__path__: /path/to/testlog
Log file contents:
user@servername: promtail$ cat /path/to/testlog
1623180833.246 192.168.0.1 POST TLSv1.2 /domain.com/java/somepath/anotherpath/en/somemodule/someservice.asmx 200 75201 76955 75201 - 5568 "-" "Java/1.8.0_281" "-" "domain.com" "text/xml" 0 153 69 "306dd6ab" - "miss" "origin" 1 1 192.168.0.1
Promtail configuration test showing the timestamp being correctly parsed:
user@servername: promtail$ cat /path/to/testlog | ./promtail-linux-amd64 -stdin -dry-run -config.file config.yml -log.level=error
Clients configured:
url: http://localhost:3100/loki/api/v1/push
batchwait: 1s
batchsize: 1048576
backoff_config:
min_period: 500ms
max_period: 5m0s
max_retries: 10
timeout: 10s
tenant_id: ""
2021-06-08T19:33:53 {__path__="/path/to/testlog", job="testjob"} 1623180833.246 192.168.0.1 POST TLSv1.2 TLSv1.2 /domain.com/java/somepath/anotherpath/en/somemodule/someservice.asmx 200 75201 76955 75201 - 5568 "-" "Java/1.8.0_281" "-" "domain.com" "text/xml" 0 153 69 "306dd6ab" - "miss" "origin" 1 1 192.168.0.1
Promtail startup with no errors:
user@servername: promtail$ ./promtail-linux-amd64 -config.file config.yml -log.level=debug
level=debug ts=2021-06-23T15:34:36.644561191Z caller=manager.go:195 component=discovery msg="Starting provider" provider=static/0 subs=[testjob]
level=debug ts=2021-06-23T15:34:36.645045056Z caller=manager.go:213 component=discovery msg="Discoverer channel closed" provider=static/0
level=info ts=2021-06-23T15:34:36.645210572Z caller=server.go:229 http=[::]:9080 grpc=[::]:43554 msg="server listening on addresses"
level=info ts=2021-06-23T15:34:36.645733248Z caller=main.go:112 msg="Starting Promtail" version="(version=2.2.1, branch=HEAD, revision=babea82e)"
level=debug ts=2021-06-23T15:34:41.645037307Z caller=filetargetmanager.go:200 msg="new target" labels="{__address__=\"localhost\"}"
level=info ts=2021-06-23T15:34:41.645211904Z caller=filetargetmanager.go:254 msg="Adding target" key="{job=\"testjob\"}"
level=debug ts=2021-06-23T15:34:41.655928548Z caller=filetarget.go:249 msg="watching new directory" directory=/path/to
level=debug ts=2021-06-23T15:34:41.656031336Z caller=filetarget.go:283 msg="tailing new file" filename=/path/to/testlog
level=info ts=2021-06-23T15:34:41.657476119Z caller=tailer.go:125 component=tailer msg="tail routine: started" path=/path/to/testlog
ts=2021-06-23T15:34:41.657633502Z caller=log.go:124 level=info msg="Seeked /path/to/testlog - &{Offset:0 Whence:0}"
Simple Loki query below, with the time picker set to ‘Last 90 days’:
{job="testjob"}
Loki log contents showing zero rows returned:
level=info ts=2021-06-23T15:34:57.351098343Z caller=metrics.go:91 org_id=fake traceID=56a382fbe2ffe4e6 latency=fast query="{job=\"testjob\"}" query_type=limited range_type=range length=720h0m1s step=20m0s duration=2.20676ms status=200 limit=1000 returned_lines=0 throughput=0B total_bytes=0B
When commenting out the following 3 lines in the promtail config, the log line shows up in Loki using the same query, but with an incorrect (ingested time) timestamp. What am I doing wrong?
- timestamp:
source: time
format: Unix
