queryError: expanding series: closed SeriesSet
    10.0.0
    I simply want to read the data from my bright computing clusters.
    Bright supports prometheus out of the box.
  • What happened?
    Thing are inconsistent. If I search the query in the explore tab searching a specific node it works just fine. As soon as I put it into a dashboard everything starts throwing errors.
    Data to be shown in the dashboard.
    gpu_utilization{hostname=~“$node”, parameter=“average”}
    Status: 500. Message: queryError: expanding series: closed SeriesSet
    Bright computing has a support doc for adding prometheus to grafana.
    How do I use Grafana to visualize monitoring data from a Bright cluster? | Bright Cluster Manager Knowledge Base
I think I figured it out. My variable was querying too much and taking too long and it was timing everything else out.
