Query speeds or alternate visuals
    • “12.4.0-20781422371.patch2”
    • A dashboard that tracks over 200 tags
    • Query the tags from AWS-IoT-SiteWise with the polystat visual
  • What happened?
    • It loads and looks good, but way to slow
    • What it did but faster
    • No
    • No
So to explain in a different way then just answering the questions…
I am trying to build a dashboard that tracks over 200 tags and display it using polystat, but it is loading very slowly, i was hoping i could get some ideas or ways to either display it similarly with different visuals that may load quicker or another way to get all the tags quicker from AWS. They are sent to AWS SiteWise, from N3uron using an edge gateway classic streams v2 gateway. Attached is an example of what I currently have with few tags and it already has noticeably slow loads on “critical” and '‘High” visuals.
how long is the query when used in grafana vs when used directly outside of grafana? Can you post some numbers?
Also can you look at your browser network tab and see what is taking the longest period of time?
