Hi All,
According to frontend_worker_config configuration(here), we need to provide the “frontend_address”, but it only support one frontend, I wonder how to do the frontend HA and does reduce the worker.
As far as I understand it the Query Frontend is meant to only run 1 instance that all the querier processes talk to.
1 Query Frontend that marshals queries to the workers.
Hi @keeganop ,
Thanks for your reply. I just worry about that, only one query frontend, if the query frontend didn’t work for some reason,then the query feature will be not work. That’s why I am thinking, any way to do the HA for query frontend.
