I’m running Pyroscope in a docker container on an ec2 instance in AWS. I configured Pyroscope’s object storage for S3. When I start it up, it prints errors such as this, and then the process dies
ts=2024-08-23T22:58:31.695121133Z caller=compactor.go:585 level=error component=compactor component=compactor msg="failed to discover users from bucket" err="Access Denied"
ts=2024-08-23T22:58:32.70247757Z caller=module_service.go:118 level=warn msg="module failed with error" module=tenant-settings err="upload s3 object: Access Denied"
ts=2024-08-23T22:58:32.702555931Z caller=phlare.go:436 level=error msg="module failed" module=tenant-settings error="upload s3 object: Access Denied"
I am using an IAM instance profile to give the ec2 instance permission to access the bucket. I was able to install the aws cli on the ec2 instance and issue a list bucket on my bucket and have it succeed.
The IAM Policy is currently all encompassing for debugging purposes:
"Version": "2012-10-17",
"Statement": [
"Sid": "PyroscopeStorage",
"Effect": "Allow",
"Action": [
"s3:*"
"Resource": [
"arn:aws:s3:::my-bucket-name",
"arn:aws:s3:::my-bucket-name/*"
The configuration is:
multitenancy_enabled: true
server:
log_level: debug
storage:
backend: s3
s3:
bucket_name: my-bucket-name
region: us-west-2
endpoint: s3.us-west-2.amazonaws.com
secret_access_key: ""
access_key_id: ""
sse:
type: SSE-S3
http:
idle_conn_timeout: 1m30s
response_header_timeout: 2m0s
insecure_skip_verify: false
tls_handshake_timeout: 10s
expect_continue_timeout: 1s
max_idle_connections: 100
max_idle_connections_per_host: 100
max_connections_per_host: 0
ingester:
lifecycler:
ring:
kvstore:
store: inmemory
analytics:
reporting_enabled: false
I have set up mimir and loki also with an s3 storage backend, and they work correctly (different buckets, but same ec2 instance and same approach).
An additional detail: S3 is being accessed via a VPC Gateway Endpoint.
What could the issue be? Thanks
