I have a photovoltaics and am logging daily values to a mariadb.
I have values for daily production, consumption and selling.
What I want to have is a bar graph with daily production and consumption like in the pic attached, but the values should be displayed, including the daily total (production + consumption). Bedide those there should be a daily bar for selling (at this moment still zero as I can not sell yet).
Is this possible? How?
Welcome
Yes it is possible. Please post table schema and data types?
-- fhem.history definition
CREATE TABLE `history` (
`TIMESTAMP` timestamp NOT NULL DEFAULT current_timestamp() ON UPDATE current_timestamp(),
`DEVICE` varchar(64) DEFAULT NULL,
`TYPE` varchar(64) DEFAULT NULL,
`EVENT` varchar(512) DEFAULT NULL,
`READING` varchar(128) DEFAULT NULL,
`VALUE` varchar(128) DEFAULT NULL,
`UNIT` varchar(32) DEFAULT NULL,
KEY `Search_Idx` (`DEVICE`,`READING`,`TIMESTAMP`),
KEY `date` (`TIMESTAMP`,`DEVICE`)
) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_bin;
Also some sample data so we can know what is considered consumption and production etc
| datum | device | event | reading | value |
| 2023-06-09 | sungrow_daily | taeglich_Daily_PV_Generation: 32.5 | taeglich_Daily_PV_Generation | 32.5 |
| 2023-06-09 | sungrow_daily | taeglich_Direct_Energy_Consumption: 27.3 | taeglich_Direct_Energy_Consumption | 27.3 |
| 2023-06-08 | sungrow_daily | taeglich_Daily_PV_Generation: 32.5 | taeglich_Daily_PV_Generation | 32.5 |
| 2023-06-08 | sungrow_daily | taeglich_Direct_Energy_Consumption: 26.8 | taeglich_Direct_Energy_Consumption | 26.8 |
| 2023-06-07 | sungrow_daily | taeglich_Daily_PV_Generation: 32.4 | taeglich_Daily_PV_Generation | 32.4 |
| 2023-06-07 | sungrow_daily | taeglich_Direct_Energy_Consumption: 26.5 | taeglich_Direct_Energy_Consumption | 26.5 |
| 2023-06-06 | sungrow_daily | taeglich_Daily_PV_Generation: 31.2 | taeglich_Daily_PV_Generation | 31.2 |
| 2023-06-06 | sungrow_daily | taeglich_Direct_Energy_Consumption: 26.7 | taeglich_Direct_Energy_Consumption | 26.7 |
hope the format is ok, unit of value is kWh
taeglich_Daily_PV_Generation is the energy created by my PV, taeglich_Direct_Energy_Consumption is the energy I have to buy.
forgot to mention that the real source for grafana is a tiny view on the table of the posting above (mainly for getting a date field without time):
CREATE OR REPLACE
ALGORITHM = UNDEFINED VIEW `sungrow_daily` AS
select
cast(`history`.`TIMESTAMP` as date) AS `datum`,
`history`.`DEVICE` AS `device`,
`history`.`EVENT` AS `event`,
`history`.`READING` AS `reading`,
`history`.`VALUE` AS `value`
from
`history`
where
`history`.`DEVICE` = 'sungrow_daily';
color is a bit wack using bar chart, you could also try time series.
Time Series
I used the following query in microsoft sql, should be easy in mysql also
This approach seems a bit tedious but less tedious than pivots.
;with src as
select '2023-06-09' as datum, 'sungrow_daily' as device, 'taeglich_Daily_PV_Generation: 32.5' as junk, 'taeglich_Daily_PV_Generation' as reading, 32.5 value union
select '2023-06-09', 'sungrow_daily', 'taeglich_Direct_Energy_Consumption: 27.3', 'taeglich_Direct_Energy_Consumption', 27.3 union
select '2023-06-08', 'sungrow_daily', 'taeglich_Daily_PV_Generation: 32.5 ' , 'taeglich_Daily_PV_Generation', 32.5 union
select '2023-06-08', 'sungrow_daily', 'taeglich_Direct_Energy_Consumption: 26.8', 'taeglich_Direct_Energy_Consumption', 26.8 union
select '2023-06-07', 'sungrow_daily', 'taeglich_Daily_PV_Generation: 32.4 ' , 'taeglich_Daily_PV_Generation', 32.4 union
select '2023-06-07', 'sungrow_daily', 'taeglich_Direct_Energy_Consumption: 26.5', 'taeglich_Direct_Energy_Consumption', 26.5 union
select '2023-06-06', 'sungrow_daily', 'taeglich_Daily_PV_Generation: 31.2 ' , 'taeglich_Daily_PV_Generation', 31.2 union
select '2023-06-06', 'sungrow_daily', 'taeglich_Direct_Energy_Consumption: 26.7', 'taeglich_Direct_Energy_Consumption', 26.7
select gen.device, gen.datum, gen.value as generated, con.value as consumed, gen.value + con.value as total
from ( select * from src where reading = 'taeglich_Daily_PV_Generation') gen
join (select * from src where reading = 'taeglich_Direct_Energy_Consumption') con
on gen.datum = con.datum
and gen.device = con.device
Thanks a lot man! Much better now using time series.
Just two more questions:
- (how) is it possible to disable time in the x-axis legend? (12:00 am does not make sense)
- would it be possible to stack generated and consumed in the bars and have the total only in tooltip?
Best regards, thanks again and thanks in advance,
Otto
- Use some sort of date format function that strips the tine off
