I’m trying to setup a multi-tenant log collection in AWS EKS.
Promtail match stage works well, JSON and labels, but the tenant doesn’t apply.
There’s a single fake directory in the S3 bucket and it seems it sends an empty tenant value, I can receive logs using this query:
{namespace="podinfo", __tenant_id__=""}
This query returns no logs:
{namespace="podinfo", __tenant_id__="admin"}
Also, I can query all logs even with X-Scope-OrgID header set in Grafana and address Loki directly, or send header with reverse proxy.
I’m using this chart
version 2.8.7
Here are my Helm chart values:
loki:
auth_enabled: true
extraVolumes:
- name: reverse-proxy-auth-config
secret:
secretName: reverse-proxy-auth-config
extraContainers:
image: k8spin/loki-multi-tenant-proxy:v1.0.0
args:
- "run"
- "--port=3101"
- "--loki-server=http://localhost:3100"
- "--auth-config=/etc/reverse-proxy-conf/authn.yaml"
ports:
- name: http
containerPort: 3101
protocol: TCP
resources:
limits:
cpu: 250m
memory: 200Mi
requests:
cpu: 50m
memory: 40Mi
volumeMounts:
mountPath: /etc/reverse-proxy-conf
extraPorts:
## Additional ports to the loki services. Useful to expose extra container ports.
- port: 3101
protocol: TCP
targetPort: http
config:
schema_config:
configs:
store: boltdb-shipper
object_store: s3
schema: v11
index:
prefix: loki_index_
period: 24h
compactor:
working_directory: /tmp/loki/compactor
shared_store: s3
common:
ring:
kvstore:
store: inmemory
path_prefix: /tmp/loki
storage:
s3:
bucketnames: logging-storage-loki
region: ap-northeast-1
access_key_id: null
secret_access_key: null
storage_config:
aws:
s3: s3://ap-northeast-1/logging-storage-loki
s3forcepathstyle: true
insecure: false
sse_encryption: false
boltdb_shipper:
shared_store: s3
cache_ttl: 24h
prometheus:
enabled: false
test:
enabled: false
grafana:
enabled: true
image:
repository: grafana/grafana
tag: "9.3.1"
pullPolicy: IfNotPresent
promtail:
enabled: true
config:
snippets:
relabel_configs:
- action: replace
target_label: namespace
source_labels:
- __meta_kubernetes_namespace
pipelineStages:
- cri: {}
- match:
selector: '{namespace=~"podinfo|test"}'
stages:
- json:
expressions:
caller: caller
- labels:
caller:
- tenant:
value: admin
