The template stage cannot reference the values in the map (the values are all empty)
- k8s uses docker CRI
Here is my log sample:
2022-11-10 18:14:51,982 [,] INFO [AsyncResolver-bootstrap-executor-0] com.netflix.discovery.shared.resolver.aws.ConfigClusterResolver: Resolving eureka endpoints via configuration
regex:
(?P<time>\d+-\d+-\d+\s\S+)\s\[(?P<trace>\w*),(?P<span>\w*)]\s(?P<level>\w+)\s+\[(?P<thread>[^]]+)]\s(?P<class>[^:]+):\s(?P<message>.*)
regex works fine and can extract fields into map
Promtail configuration file:
- job_name: my-job
pipeline_stages:
- docker: {}
- multiline:
firstline: '^\d+-\d+-\d+\s\d+:\d+:\d+,\d+\s'
max_wait_time: 5s
max_lines: 128
- regex:
expression: '(?P<time>\d+-\d+-\d+\s\S+)\s\[(?P<trace>\w*),(?P<span>\w*)]\s(?P<level>\w+)\s+\[(?P<thread>[^]]+)]\s(?P<class>[^:]+):\s(?P<message>.*)'
- labels:
level:
- template:
source: out_message
template: '{"time": "{{ .time }}", "trace": "{{ .trace }}", "span": "{{ .span }}", "level": "{{ .level }}", "thread": "{{ .thread }}", "class": "{{ .class }}", "message": "{{ .message }}"}'
- output:
source: out_message
The output is not as expected, all json keys have empty values!
promtail image:
image: grafana/promtail:2.5.0
imageID: docker-pullable://grafana/promtail@sha256:8cce5a28c6515ec88603caf07236855873b2a574f23891ddffb269d60a74ed42
My configuration looks correct, but I don’t know why it doesn’t work, and I didn’t find an answer on the internet, please help ! Thanks all
