Hi
I am trying to parse timestamp from the log below.
(I)20250219:092344315306[085938] Recv Req :len[1076]data[1072HPS97709230010 ...
I wrote config as below, but it doesn’t work.
scrape_configs:
- job_name: access_log
pipeline_stages:
- regex:
expression: '^\(I\)(?P<timestamp>\d{8}:\d{12}).*$'
- timestamp:
source: timestamp
format: "20060102:150405000000"
inspect: regex stage]:
{stages.Entry}.Extracted["timestamp"]:
+: 20250219:092344315306
[inspect: timestamp stage]: none
2025-02-19T18:31:10.636988825+0900 {} (I)20250219:092344315306[085938] Recv Req :len[1076]data[1072H
Also, when I reduced the seconds as below, it worked normally.
scrape_configs:
pipeline_stages:
- regex:
expression: '^\(I\)(?P<timestamp>\d{8}:\d{6}).*$'
- timestamp:
source: timestamp
format: "20060102:150405"
[inspect: regex stage]:
+: 20250219:092344
{stages.Entry}.Entry.Entry.Timestamp:
-: 2025-02-19 18:32:33.178119831 +0900 KST
+: 2025-02-19 09:23:44 +0900 KST
2025-02-19T09:23:44+0900 {} (I)20250219:092344315306[085938] Recv Req :len[1076]data[1072H
I am trying to parse based on the original seconds. Is there a way to solve it?
