Greetings folks,
I have reached the end of the internet, searched everywhere. Decided to post here, I’d appreciate some help.
My log file is json formatted that looks like this:
{"timestamp": "2022-11-21T23:53:29.836288+00:00", "method": "GET", "path": "/login", "level": "info"}
When parsing using promtail pipeline stages, I have the following timestamp format:
scrape_configs:
- job_name: my_job
pipeline_stages:
- json:
expressions:
time: timestamp
timestamp:
source: time
format: 2006-01-02T15:04:05.000000-07:00
static_configs:
- targets:
- localhost
labels:
job: web-access
__path__: /var/log/my_project/web_access.log
But when running promtail and checking the logs in Loki, the line timestamp is always the time when promtail exported the logs, but not the actual time of the event from the json timestamp field. This is the default that I am trying to override.
Any thing I am doing wrong here? I’ve tried various things from changing the key “timestamp”, “time”, etc. Also read all stackoverflow posts associated with this issue.
Thank you!
NPG
