For some mysterious and unknown reason, after upgrading our EKS cluster, promtail changed the way it assigned some labels. Is there any way to make it assign the values as it used to?
Before:
Now:
Note that before the upgrade, the “app” label was called “tavola-app” and now promtail is taking the name of the replicaset to define the “app” label.
My config file:
server:
log_level: info
http_listen_port: 3101
clients:
- basic_auth:
password:
username:
url: http://loki-gateway/loki/api/v1/push
positions:
filename: /run/promtail/positions.yaml
scrape_configs:
- job_name: kubernetes-pods
pipeline_stages:
- cri: {}
- match:
selector: '{job="traefik/traefik"}'
stages:
- drop:
expression: .ping.|healthcheck
kubernetes_sd_configs:
- role: pod
relabel_configs:
- source_labels:
- __meta_kubernetes_pod_controller_name
regex: ([0-9a-z-.]+?)(-[0-9a-f]{8,10})?
action: replace
target_label: __tmp_controller_name
- source_labels:
- __meta_kubernetes_pod_label_app_kubernetes_io_name
- __tmp_controller_name
- __meta_kubernetes_pod_name
regex: ^;*([^;]+)(;.*)?$
action: replace
target_label: app
- source_labels:
- __meta_kubernetes_pod_label_app_kubernetes_io_instance
- __meta_kubernetes_pod_label_release
action: replace
target_label: instance
- source_labels:
- __meta_kubernetes_pod_label_app_kubernetes_io_component
- __meta_kubernetes_pod_label_component
action: replace
target_label: component
- action: replace
source_labels:
- __meta_kubernetes_pod_node_name
target_label: node_name
- action: replace
source_labels:
- __meta_kubernetes_namespace
target_label: namespace
- action: replace
replacement: $1
separator: /
source_labels:
- namespace
- app
target_label: job
- action: replace
source_labels:
target_label: pod
- action: replace
source_labels:
- __meta_kubernetes_pod_container_name
target_label: container
- action: replace
replacement: /var/log/pods/*$1/*.log
separator: /
source_labels:
- __meta_kubernetes_pod_uid
target_label: __path__
- action: replace
regex: true/(.*)
separator: /
source_labels:
- __meta_kubernetes_pod_annotationpresent_kubernetes_io_config_hash
- __meta_kubernetes_pod_annotation_kubernetes_io_config_hash
limits_config:
tracing:
enabled: false
