Hello, team!
I would like to find way to drop certain logs. Is there any example how to do that?
Thank you so much in an advance!
Hello, team!
You can use pipeline stages to filter, refer to this documentation:
The match stage conditionally executes a set of stages when a log entry matches a configurable LogQL stream selector.
Hope it helps.
Good Luck
Thank you! I will take a look at it!
I have the same question as well.
here is what I am trying to do.
snippets:
pipelineStages:
- cri: {}
- match:
selector: '{app_kubernetes_io_name="ingress-nginx"}'
action: drop
- labels:
cluster: rancher
However, this doesn’t really work because the selector doesn’t catch anything
The label is like app.kubernetes.io/name: ingress-nginx
What is the correct syntax to do this?
I have tried __meta_kubernetes_pod_label_app_kubernetes_io_name and it doesn’t work either.
Thx
If you are setting up for the first time, i suggest you follow the setup on this article (configuration side)
Hope it helps.
Good Luck
