Hi!
I just installed promtail in one of our K8S clusters using the directions on Grafana Cloud.
curl -fsS https://raw.githubusercontent.com/grafana/loki/master/tools/promtail.sh | sh -s 1122334 <Your Grafana.com API Key> logs-prod-us-central1.grafana.net default | kubectl apply --namespace=default -f -
This worked, and I have cluster logs flowing into Loki. But what I really want to do is restrict what logs are sent to Loki. Mostly because we have a lot of pods we don’t need logging on, and I’m trying to limit the logs going into Grafana Cloud and stay under the 50GB limit until we can get our own Loki environment locally.
I’d really like to have an annotation on the pods that promtail uses to determine if the logs should be scrapped or not. Like with prometheus having an annotation for prometheus.io/scrape=true. Next best solution would be to restrict it based on the namespaces we want to scrape pods in.
So I believe I need to do a match with a selector and an action of drop.
- match:
selector: '{promtail="true"}
action: drop
However the promtail.yml configmap created by the promtail.sh script doesn’t seem to match the documentation on the promtail site about how the file should be.
According to the documentation, I should see something like:
scrape_configs:
- job_name: kubernetes-pods-name
kubernetes_sd_configs: ....
pipeline_stages:
# This stage is only going to run if the scraped target has a label
# of "name" with value "promtail".
- match:
selector: '{name="promtail"}'
stages:
- docker{}
But the configmap created is completely different, with the parsing stage of docker before the kubernetes_sd_configs - and I put the match at the end?
8 scrape_configs:
9 - pipeline_stages:
10 - docker:
11 job_name: kubernetes-pods-name
12 kubernetes_sd_configs:
13 - role: pod
14 relabel_configs:
15 - source_labels:
16 - __meta_kubernetes_pod_label_name
17 target_label: __service__
18 - source_labels:
19 - __meta_kubernetes_pod_node_name
20 target_label: __host__
21 - action: drop
22 regex: ^$
23 source_labels:
24 - __service__
25 - action: replace
26 replacement: $1
27 separator: /
28 source_labels:
29 - __meta_kubernetes_namespace
30 - __service__
31 target_label: job
32 - action: replace
33 source_labels:
34 - __meta_kubernetes_namespace
35 target_label: namespace
36 - action: replace
37 source_labels:
38 - __meta_kubernetes_pod_name
39 target_label: instance
40 - action: replace
41 source_labels:
42 - __meta_kubernetes_pod_container_name
43 target_label: container_name
44 - replacement: /var/log/pods/*$1/*.log
45 separator: /
46 source_labels:
47 - __meta_kubernetes_pod_uid
48 - __meta_kubernetes_pod_container_name
49 target_label: __path__
50 - match:
51 selector: '{promtail="true"}
52 action: drop
Can anyone provide any insight into how I can accomplish this?
Thanks!
