I had a Loki setup running successfully but after an update using docker-compose pull and docker-compose up -d, the Promtail container is in restarting loop.
version: '3.7'
  loki:
    container_name: loki
    image: grafana/loki
    networks:
      - loki
    restart: unless-stopped
    ports:
      - '3100:3100'
    command: -config.file=/etc/loki/local-config.yaml
  promtail:
    container_name: promtail
    image: grafana/promtail
    networks:
      - loki
    volumes:
      - /var/log:/var/log
    command: -config.file=/etc/promtail/docker-config.yaml
  grafana:
    image: grafana/grafana
    container_name: grafana
    networks:
      - loki
    user: 1000
    ports:
      - '3000:3000'
    environment:
      - GF_SECURITY_ADMIN_PASSWORD=admin
      - GF_RENDERING_SERVER_URL=http://renderer:8081/render
      - GF_RENDERING_CALLBACK_URL=http://grafana:3000
      - GF_LOG_FILTERS=rendering:debug
    volumes:
      - /media/data/grafana:/var/lib/grafana
    user: "1000:1001"
The logs show following error:
Unable to parse config: open /etc/promtail/docker-config.yaml: no such file or directory
I don’t ever remember configuring that file and since I don’t have a volume attached to it, I am not sure where to look for the config file. Any help would be appreciated.
