Prometheus write_relabel_configs with both keep and replace action not working
Hi, I am trying to send metrics from Prometheus to Grafana cloud with below config.
remote_write:
- url: https://prometheus-us-central1.grafana.net/api/prom/push
  write_relabel_configs:
  - source_labels: [__name__]
    separator: ;
    regex: (container_.*|jvm_.*)
    replacement: $1
    action: keep
    separator: ;
    regex: workload:(.*)
    target_label: __name__
    replacement: $1
    action: replace
I see metrics only from keep but not from replace relabel config in Grafana cloud.
The requirement is to send some metrics without any changes and other metrics with renaming. For example, workload:istio_requests_total to istio_requests_total
Below config worked. First select metric using keep and then rename using replace.
remote_write:
    separator: ;
    regex: (jvm_.*|workload:.*)
    replacement: $1
    action: keep
    separator: ;
    replacement: $1
    action: replace
