Docker image: prom/prometheus:v2.51.2
OS: Ubuntu 22.04 -
I want to drop specific metrics so they don’t get ingested into prometheus. -
Thats the config:
scrape_configs:
- job_name: bamboo
metrics_path: /bamboo/plugins/servlet/prometheus/metrics
scheme: https
static_configs:
- targets:
- redacted.com
metric_relabel_configs:
- source_labels: [__name__]
regex: bamboo_build_*
action: drop
I tried metric_label_configs and relabel_configs:
relabel_configs:
- action: labeldrop
regex: bamboo_build_duration_histogram_bucket
What happened?
The metric is still processed by prometheus and also accessable in grafana. -
It should not be acessable in grafana. -
See above -
No errors in prometheus or grafana. -
Reduce metrics costs by filtering collected and forwarded metrics | Grafana Cloud documentation
