Hi all,
I’m trying to set up prometheus.exporter.cadvisor to monitor all containers. However, I only get metrics for the alloy container itself.
I’m running alloy inside docker container, mounted /var/run/docker.sock inside container
config file:
prometheus.exporter.cadvisor "example" {
docker_host = "unix:///var/run/docker.sock"
storage_duration = "5m"
// Configure a prometheus.scrape component to collect cadvisor metrics.
prometheus.scrape "scraper" {
targets = prometheus.exporter.cadvisor.example.targets
forward_to = [ prometheus.remote_write.demo.receiver ]
prometheus.remote_write "demo" {
endpoint {
url = PROMETHEUS_REMOTE_WRITE_URL
basic_auth {
username = USERNAME
password = PASSWORD
I’ve not tried this myself, but couple of things you could try:
You might need to mount /var/lib/docker as RO as well.
Make sure your alloy container is privileged.
Hi, I’ve encountered the same problem (I am running Alloy in compose with ‘pid’ and ‘network_mode’ set to ‘host’, without ‘privileged: true’). To get metrics from all containers (via cadvisor component) on the host, I had to add the following volumes:
/:/rootfs
/var/run:/var/run
/sys:/sys
/var/lib/docker/:/var/lib/docker
fredgb
December 28, 2024, 4:33pm
4
Bonjour,
I have the same problem, but, I not sure of your advice @jakubzukal , or I simply don’t understand, sorry…
This is a part of my docker compose:
alloy:
image: grafana/alloy:latest
container_name: alloy
restart: "always"
command:
- run
- /etc/alloy/
- --storage.path=/var/lib/alloy/data
- --server.http.listen-addr=0.0.0.0:12345
- --stability.level=experimental
ports:
- 12345:12345
- 9001:9001
- 9002:9002
- 4318:4318
- 4317:4317
volumes:
- "/var/run/docker.sock:/var/run/docker.sock:ro"
- "/var/log:/host-var-log"
- "/proc:/host-proc"
- "/sys:/host-sys"
- "/:/host-root"
- "/run/udev/data:/host-udev"
- "/data/etc/alloy:/etc/alloy"
- "/data/var/lib/alloy/data:/var/lib/alloy/data"
labels:
- "traefik.enable=false"
cap_add:
- SYS_PTRACE
- SYS_TIME
privileged: true
cadvisor:
image: gcr.io/cadvisor/cadvisor:latest
container_name: cadvisor
volumes:
- /:/rootfs:ro
- /var/run:/var/run:rw
- /sys:/sys:ro
- /var/lib/docker/:/var/lib/docker:ro
If I have already mount in my alloy configuration /, sys to be used with prometheus.exporter.unix . How I can use it for cAdvisor?
Thanks!
you dont have to run cadvisor sideways. Use alloy cadvisor component , if possible.
I am using the following compose (template) with other components (exporters: cadvidor, kafka, unix, loki: remote syslog, journald)
version: '3'
services:
grafana-alloy:
container_name: grafana-alloy
hostname: {{ alloy_hostname }}
image: grafana/alloy:{{ alloy_docker_tag }}
ports:
- "{{ alloy_http_listen_port }}:{{ alloy_http_listen_port }}/tcp"
volumes:
- /var/lib/alloy/data
- type: bind
source: ./confs
target: /etc/alloy/confs
read_only: true
- type: bind
source: /
target: /rootfs
read_only: true
- type: bind
source: /var/run
target: /var/run
read_only: true
- type: bind
source: /var/log
target: /var/log
read_only: true
- type: bind
source: /sys
target: /sys
read_only: true
- type: bind
source: /var/lib/docker/
target: /var/lib/docker/
read_only: true
- type: bind
source: /run/udev/data
target: /run/udev/data
read_only: true
environment:
pid: host
network_mode: host
cap_add:
- SYS_TIME
- SYS_PTRACE
security_opt:
- apparmor=unconfined
command: run --server.http.listen-addr=0.0.0.0:{{ alloy_http_listen_port }} --storage.path=/var/lib/alloy/data /etc/alloy/confs
restart: unless-stopped
and Alloy’s cAdvisor config
prometheus.exporter.cadvisor "docker" {
docker_only = true
prometheus.scrape "cadvisor" {
targets = prometheus.exporter.cadvisor.docker.targets
forward_to = [prometheus.relabel.cadvisor.receiver]
prometheus.relabel "cadvisor" {
forward_to = [prometheus.remote_write.grafana_cloud.receiver]
rule {
regex = "^(container_label_com_docker_compose_.+|id|container_label_maintainer|container_label_org_opencontainers_.+)"
action = "labeldrop"
rule {
source_labels = ["__name__"]
regex = "^(container_cpu_usage_seconds_total|container_fs_inodes_free|container_fs_inodes_total|container_fs_limit_bytes|container_fs_usage_bytes|container_last_seen|container_memory_usage_bytes|container_network_receive_bytes_total|container_network_tcp_usage_total|container_network_transmit_bytes_total|container_spec_memory_reservation_limit_bytes|machine_memory_bytes|machine_scrape_error)$"
action = "keep"
