Currently I’m using an elastic seach datasource. I have keys with values just like this:
(taken from UQL Parser | Grafana Plugins documentation)
"id": 1,
"name": { "firstName": "john", "lastName": "doe" },
"dob": "1985-01-01",
"city": "chennai"
"id": 2,
"name": { "firstName": "alice", "lastName": "bob" },
"dob": "1990-12-31",
"city": "london"
I would like to break it up into individual keys so I can flatten the json and visualize the output.
I figured out how to flatten this manually values using transform : How to extract json value from elasticsearch source
but this is tedious and manual. Is there a way I can interface with an API script transformations?
OR
I would like to use UQL to do this but I think UQL only talks to API datasources from what I can tell. I can’t seem to figure out how to use UQL on elasticsearch.
just point infinity to url:9200
what do you see with the data result from that?
Oo this is promising so if I use just http://ip:9200
I see my table shows :
{ "cluster_name": "docker-cluster", "cluster_uuid": "v0UMqJ0MQiKrmg-ZaQ08pQ", "name": "elasticsearch", "tagline": "You Know, for Search", "version": { "build_date": "2022-08-23T11:08:48.893373482Z", "build_flavor": "default", "build_hash": "f65e9d338dc1d07b642e14a27f338990148ee5b6", "build_snapshot": false, "build_type": "docker", "lucene_version": "8.11.1", "minimum_index_compatibility_version": "6.0.0-beta1", "minimum_wire_compatibility_version": "6.8.0", "number": "7.17.6" } }
I got a curl to work :
curl -X POST "http://ip:9200/_sql?format=txt" -H 'Content-Type: application/json' -d '{"query": "SELECT \"label.keyword\" FROM \"indexName-*\""}'
But im not sure how to convert this curl into a URL options . For example where do I place the -d portion which has the query?
might want to read the docu
https://grafana.github.io/grafana-infinity-datasource/docs/url
can you please post a sample es document, I can try to spin one up locally and see what we can do
sample_es_doc.json (4.6 KB)
Sure here’s a sample document. I read the document link you posted… I my smooth brain just doesnt understand how to convert the curl statement which does return data successfully into something that fits in to the plugin parameters. Thanks
please also post how to enable the sql method or can you also do vanilla json return type or can you do a json data return type on that sql type?
This should get you closer
uql
parse-json
| scope "hits.hits"
Transformation Extract
you can also play around with it using jsonata a feature of UQL
https://try.jsonata.org/HUzBvNlur
Thanks for the info, I actually don’t know how to “enable sql method” . But let me look into your example thanks
