Grafana: 9.1.7
OS: Windows 10 VM -
Create a pannel with multiple queries and show them at the same time -
Grafana live measurements -
What happened?
Most of the time the pannel show the data correctly, other times only the first field is shown and the user needs to refresh the page to fix this. -
That the pannel shows all the fields all the time without needing to refresh the page. -
https://pastebin.com/G4RTRwim
Password: p4jtRMkWHe -
No
Picture for reference:
“OK” is the value of the first query: “STATUS”
