9.1.x -
Developing a backend datasource plugin -
Writing a grafana backend plugin in golang -
What happened?
I want a mechanism by which any unhandled panic (from golang code) does not bring down the backend plugin process. At the moment any downstream panic(s) raised by my golang code will freeze my backend plugin. How do I gracefully handle all panic(s) and still continue to serve my panels (like timeseries, chart etc) through my backend datasource? -
Want to gracefully handle any downstream panic(s) -
NA -
This seems more of a golang issue than grafana?
Someone might chime in but
You might get more mileage on a go lang forum?
Okay. Will try in a golang forum.
