I am using Grafana 8.3.0 -
I am trying to show multiple values in a bar-gauge. -
I used this query:
SELECT
NOW() AS time,
(ROW_NUMBER() over(order by value desc)) || '. β || name as metric,
value
FROM table
ORDER by value desc
LIMIT 10 - What happened?
They are ordered by metric name. Starts with 1. {name}, 10. {name} then goes from 2-9 - What did you expect to happen?
The result to be ordered by value and not by the name. It worked like this before the update from Grafana 7 to 8.
Also if I put ${__series.name} in the Display name field it just shows Series (A) instead of 1. {name} for example
