Is it possible to set multiple clients to send different logs to different Loki servers in a single configuration or I need to launch 2 instances of promtail to do that?
Yes, you can (provided you’re running the latest version as of Jul27,2021): Configuration | Grafana Labs
How will this look in a config? I need to know if i can make a config where the scraping of one log file goes to one client and scraping of the other will go to another client. Is this possible, or will all clients always recieve the same data?
Hi @dehoej
Did you ever find a solution? I am facing the same problem?
I use vector now. It also has support for deliverability guarantee.
