I’m deploying Grafana Alloy on Kubernetes using a DaemonSet with hostPath volumes mounting /var/log/pods and /var/log/containers from the host. The pods have this configured in the spec:
- The hostPath volumes have
DirectoryOrCreatetype set correctly. - The mounted directory
/var/log/podson the host has permissionsdrwxr-xr-x root:root.
However, inside the container, I get Permission denied when listing /var/log/pods. I have tried running as root user and group, but it still fails.
Also getting an error “source.file.pods error="stat /var/log/pods///.log: no such file or directory” filename=/var/log/pods///.log’.
What best practices should I follow to fix permission issues with hostPath mounts for log directories like /var/log/pods in Grafana Alloy? Should I use init containers to fix permissions, or adjust fsGroup differently? How can I safely allow Alloy to read these log directories without compromising cluster security?
apiVersion: collectors.grafana.com/v1alpha1
kind: Alloy
metadata:
namespace: test
spec:
controller:
type: daemonset
# enableStatefulSetAutoDeletePVC: true
tolerations:
- effect: NoSchedule
operator: Exists
volumes:
extra:
- name: pod-logs
hostPath:
path: /var/log/pods
type: DirectoryOrCreate
- name: container-logs
hostPath:
path: /var/log/containers
- name: data-vol
hostPath:
path: /var/alloy
- name: alloy-client-cert
secret:
secretName: alloy-client-cert
volumeMounts:
extra:
- name: pod-logs
mountPath: /var/log/pods
readOnly: true
mountPath: /var/log/containers
readOnly: true
mountPath: /etc/alloy/certs
readOnly: true
serviceAccount:
create: false
automountServiceAccountToken: true
rbac:
create: true
alloy:
mounts:
varlog: true
extra:
- name: data-vol
mountPath: /var/alloy
readOnly: false
configMap:
create: false
key: alloy-logs
storagePath: /var/alloy
securityContext:
runAsUser: 0
runAsGroup: 0
fsGroup: 0
configmap:
apiVersion: v1
data:
alloy-logs: |
logging {
level = “debug”
}loki.source.file "pods" { targets = [ { __path__ = "/var/log/pods/*/*/*.log" }, ] forward_to = [loki.process.pod_logs.receiver] } loki.process "pod_logs" { forward_to = [loki.write.victorialogs.receiver] } loki.write "victorialogs" { endpoint { url = "endpoitnt" tenant_id = "0:0" } external_labels = {} }kind: ConfigMap
metadata:
