Pending time for the "Configure no data and error handling" section
Hello!
I am using Grafana v11.6.2 and I set up an alert for InfluxDB that fires when a value is above a threshold after one hour of pending time.
What about the alert sent when there is no data, i.e. what is defined in the “Configure no data and error handling” section? Does the previously defined pending time also apply to this alert?
Best regards
  • What happened?
