Hello, I am using the Flowcharting Plugin for Grafana. It works perfectly when I copy the XML of the floorplan that I’ve created in draw.io into the Source Content field, however, is it possible somehow to query the XML from a postgres database?
Let’s say we create a bunch of floorplans on draw.io, then save the XML in a database, then query it in Grafana. The reason why I need something like this is because we have a variable for buildings on this particular dashboard, and it would be very nice if the floorplans could change accordingly.
If this is not possible, can you suggest a workaround?
Thank you!
