Hi Team,
I need to test one endpoint which expects body as below, i.e. tokens array
{"tokens": [{"chainId": "0x1","address": "0x000000007a58f5f58e697e51ab0357bc9e260a04"}]}
If I want to run test by passing multiple values in tokens array, like below
"tokens": [
"chainId": "0x1",
"chainId": "0x171",
"address": "0x0000000000085d4780b73119b644ae5ecd22b376"
How can I achieve using SharedArray ?
If I use the complete JSON directly in test script, it’s working
But I store test data in separate file e.g. tokens.json & call in test script
if I use SharedArray like below, it’s giving 400:"BadRequestException
Because its passing body without tokens array like below i.e.
[{"chainId":"0x1","address":"0x000000007a58f5f58e697e51ab0357bc9e260a04"}]
instead it should pass body as
Test Script
const data = new SharedArray("tokens", function () {
tokens = JSON.parse(open("./tokens.json")).tokens;
return tokens;
export default function () {
const requestUrl = "endpoint";
const result = http.post(requestUrl, JSON.stringify(data), params, {
tags: { name: "Category Tokens" },
Body:
"tokens": [
"chainId": "0x1",
"chainId": "0x171",
Thank You
