Parsing MSSQL ERRORLOG in UTF-16LE BOM encoding
I see some closed cases related to this issue:
Which I’m having a hard time to understand, as this is still not fixed though I was promised it would be fixed in Alloy v1.12.1. it still the same no matter which encoding is used, I get the same useless spaced characters as shown on the link above.
In addition, where I generate an output from SQL by wrong login, where the Alloy Live Debugging output is like this:
[IN]: timestamp: 2026-01-27T08:52:09.7433607-08:00, entry: 2026-01-27 08:52:07.91 Logon Error: 18456, Severity: 14, State: 8.
�, labels: {_log_type=“mssql_error”, filename=“C:\Program Files\Microsoft SQL Server\MSSQL15.MSSQLSERVER\MSSQL\LOG\ERRORLOG”}, structured_metadata: {}
[IN]: timestamp: 2026-01-27T08:52:09.7433607-08:00, entry: 2026-01-27 08:52:07.91 Logon Login failed for user ‘alloy’. Reason: Password did not match that for the login provided. [CLIENT: ]
[OUT]: timestamp: 2026-01-27T08:52:07.91-08:00, entry: 2026-01-27 08:52:07.91 Logon Error: 18456, Severity: 14, State: 8.
�, labels: {tenant_id=“cust_app”, component=“Logon”, filename=“C:\Program Files\Microsoft SQL Server\MSSQL15.MSSQLSERVER\MSSQL\LOG\ERRORLOG”, level=“error”, service_name=“database/mssql/error”}, structured_metadata: {“message”:“Error: 18456, Severity: 14, State: 8.\r�”}
[IN]: timestamp: 2026-01-27T08:52:10.7434033-08:00, entry: 2026-01-27 08:52:09.98 Logon Error: 18456, Severity: 14, State: 8.
[IN]: timestamp: 2026-01-27T08:52:10.7434033-08:00, entry: 2026-01-27 08:52:09.98 Logon Login failed for user ‘alloy’. Reason: Password did not match that for the login provided. [CLIENT: ]
[OUT]: timestamp: 2026-01-27T08:52:07.91-08:00, entry: 2026-01-27 08:52:07.91 Logon Login failed for user ‘alloy’. Reason: Password did not match that for the login provided. [CLIENT: ]
�, labels: {tenant_id=“cust_app”, component=“Logon”, filename=“C:\Program Files\Microsoft SQL Server\MSSQL15.MSSQLSERVER\MSSQL\LOG\ERRORLOG”, level=“error”, service_name=“database/mssql/error”}, structured_metadata: {“message”:“Login failed for user ‘alloy’. Reason: Password did not match that for the login provided. [CLIENT: \u003clocal machine\u003e]\r�”}
[OUT]: timestamp: 2026-01-27T08:52:09.98-08:00, entry: 2026-01-27 08:52:09.98 Logon Error: 18456, Severity: 14, State: 8.
[OUT]: timestamp: 2026-01-27T08:52:09.98-08:00, entry: 2026-01-27 08:52:09.98 Logon Login failed for user ‘alloy’. Reason: Password did not match that for the login provided. [CLIENT: ]
Grafana can’t even show the logs, but throughs the error:
So I’d be really happy to know where the solution is, and why the above cases has been closed, when this obviously has not been fixed yet?
What’s your Alloy configuration?
Do you mean the config.alloy content or more precisely what?
Yes, can you share your config.alloy, please?
Also, if you have a sample file that’s UTF-16 encoded that would be great, too.
HI @tonyswumac,
This was finally fixed by support in v1.13.0, and sorry for my late response.
