Panic internal errors while running xk6-browser GitHub action
Hi everyone,
I’m new to xk6-browser and am currently facing some issues while using it in a xk6-browser GitHub action to conduct a load test with over 100 VUs (max 300) performing various interactions like button clicks to navigate the site.
The issues seem to occur once there are more than 100 VUs as the test would then fail. At the moment, I’m not clear as to why that specific threshold causes panic internal error failures. Browsing the community forum hasn’t quite revealed an answer/solution (maybe I’m just missing something).
Below that number, the tests can successfully execute to the end with multiple VUs and without a panic error failure. The script used is as follows:
/* global __ENV:false */
import { check } from 'k6';
import exec from 'k6/execution';
import { chromium } from 'k6/x/browser';
// GitHub Action secret with the URL of the site to load test.
const SITE = __ENV.load_test_site;
// GitHub Action secret with email:password pairing in a comma-separated string.
const USERS = __ENV.load_test_users.split( ',' );
export let options = {
	scenarios: {
		load_testing: {
			executor: 'per-vu-iterations',
			exec: 'load_test',
			vus: USERS.length,
			iterations: 1,
export function load_test() {
	const browser = chromium.launch(
			headless: true,
	const page = browser.newPage();
	page
		.goto( SITE, { waitUntil: 'load' } )
		.then( () => {
			const user = USERS[exec.vu.idInTest - 1].split( ':' );
			page.locator( '#user_login' ).type( user[0] );
			page.locator( '#user_pass' ).type( user[1] );
			// Wait for asynchronous operations to complete.
			return Promise.all( [
				page.waitForNavigation(),
				page.locator( '#wp-submit' ).click(),
			] ).then( () => {
				check( page, {
					'Logged in and on the homepage.': page.locator( 'h1.search__title' ).textContent().trim() === 'Homepage',
		} ).then( () => {
				page.locator( 'a[href="/url1"]' ).click(),
			] ).then( () => {
				check( page, {
					'Navigated to URL 1 page.': page.locator( 'h1.heading-1' ).textContent().trim() === 'URL 1 page',
		} ).then( () => {
				page.locator( 'a[href="/url2"]' ).click(),
			] ).then( () => {
				check( page, {
					'Navigated to URL 2 page.': page.locator( 'h1.heading-1' ).textContent().trim() === 'URL 2 page',
		} ).then( () => {
			// Switch pages using the navigation.
				page.locator( 'div.dropdown-wrapper > button.trigger-dropdown' ).click(),
				page.locator( 'div.dropdown-menu > button:first-child' ).click(),
			] ).then( () => {
				check( page, {
					'Navigated to URL 3 page.': page.locator( 'h1.heading-1' ).textContent().trim() === 'URL 3 page',
		} ).then( () => {
			// Attempt to search for something.
			page.locator( '#search-header' ).type( 'Account' );
				page.locator( 'div.wp-block-search__inside-wrapper > button[type="submit"]' ).click(),
			] ).then( () => {
				// Check if the search results page.
				check( page, {
					'Navigated to Search results page.': page.locator( 'div.search-results-content' ),
		} ).finally( () => {
			page.close();
			browser.close();
The different panic internal errors I observed can be seen in the image below.
Any pointers on how to resolve them would be greatly appreciated.
Hi @rayhatron For xk6 browser i’m not recommended to run with many users because process open browser consume huge resources from load generators and result errors.
Hi @rayhatron,
As @Elibarick has already pointed out, the k6-browser module will spin up a new browser instance as a child process per vu. So if you have a test running 100 vus, that’s 100 Chrome/Chromium browser instances. To be able to run such a test you will need a large beefy system (lots of ram, many CPU cores, etc) to be able to tackle that work load.
To work effectively with k6-browser module, it’s best to take a hybrid approach. There’s a great blog which explains what that means here: Get Started with k6 browser.
Hope this helps.
Cheers,
Ankur
Thank you @Elibarick and @ankur. I’ll take a look at that hybrid testing approach since it seems that’s the solution as the errors are unavoidable at high VUs.
