Good Day
I am trying to create multiple panels that take info from a different set of metrics and change the colour of the panel receiving the data. An example would be
A client with a name Fabrico, Fabrico has zabbix pulling data from their servers and router using Zabbix and you create a panel with the different elements like CPU, Ping, Temperature and Memory Utilization for example.
I want to create a different panel with just text called Fabrico but linked to change colour when one of the datalinks it has is affected, so if temperature goes to high, the panel changes colour then you can click on the panel and get the relevant info.
Not sure if this is possible.
