Grafana 8.0.1
- What are you trying to achieve?
I would like to write a rule in the new alerting system of Grafana that is able to be overrided by another rule for a specific label defined. For example :
global rule query : cpu_usage_system > 10
specific rule query : cpu_usage_system{host=“specific_host”} > 20
So here I would like that Grafana triggers the global rule for every host except the host “specific_host”, and it triggers the specific rule for this host.
Obviously I could define the global query like this : cpu_usage_system{host!=“specific_host”} > 10, but if I have 100 differents hosts with 100 different thresholds, that is not a clean solution.
- How are you trying to achieve it?
No solution found for now. Thanks in advance for your help
