I am trying to find a way to have failed checks reflected as errors in the CSV file (i.e. in the fields error and error_code).
Can it be somehow configured, maybe involving expected_response metric?
Thank you in advance.
More details below:
For example, my request is expected to return some error response (400) and with checks mechanism I compare actual response code to 400.
The problem for me is to detect failed responses from CSV file when I get anything else instead of 400.
In the K6 output and summary json I see the failed checks statistics, but I would like to be able to treat failed checks as errors in the CSV file.
metric_name,timestamp,metric_value,check,error,error_code,expected_response,group,method,name,proto,scenario,service,status,subproto,tls_version,url,extra_tags
http_reqs,1623681406,1.000000,,,1501,false,,POST,http://localhost:8000/abc,HTTP/1.0,options_scenario,,501,,,http://localhost:8000/abc,
http_req_duration,1623681406,5.507000,,,1501,false,,POST,http://localhost:8000/abc,HTTP/1.0,options_scenario,,501,,,http://localhost:8000/abc,
http_req_blocked,1623681406,0.630000,,,1501,false,,POST,http://localhost:8000/abc,HTTP/1.0,options_scenario,,501,,,http://localhost:8000/abc,
http_req_connecting,1623681406,0.143000,,,1501,false,,POST,http://localhost:8000/abc,HTTP/1.0,options_scenario,,501,,,http://localhost:8000/abc,
http_req_tls_handshaking,1623681406,0.000000,,,1501,false,,POST,http://localhost:8000/abc,HTTP/1.0,options_scenario,,501,,,http://localhost:8000/abc,
http_req_sending,1623681406,0.518000,,,1501,false,,POST,http://localhost:8000/abc,HTTP/1.0,options_scenario,,501,,,http://localhost:8000/abc,
http_req_waiting,1623681406,4.885000,,,1501,false,,POST,http://localhost:8000/abc,HTTP/1.0,options_scenario,,501,,,http://localhost:8000/abc,
http_req_receiving,1623681406,0.104000,,,1501,false,,POST,http://localhost:8000/abc,HTTP/1.0,options_scenario,,501,,,http://localhost:8000/abc,
http_req_failed,1623681406,1.000000,,,1501,false,,POST,http://localhost:8000/abc,HTTP/1.0,options_scenario,,501,,,http://localhost:8000/abc,
http_reqs,1623681406,1.000000,,,,true,,HEAD,http://localhost:8000,HTTP/1.0,options_scenario,,200,,,http://localhost:8000,
http_req_duration,1623681406,6.904000,,,,true,,HEAD,http://localhost:8000,HTTP/1.0,options_scenario,,200,,,http://localhost:8000,
http_req_blocked,1623681406,0.628000,,,,true,,HEAD,http://localhost:8000,HTTP/1.0,options_scenario,,200,,,http://localhost:8000,
http_req_connecting,1623681406,0.142000,,,,true,,HEAD,http://localhost:8000,HTTP/1.0,options_scenario,,200,,,http://localhost:8000,
http_req_tls_handshaking,1623681406,0.000000,,,,true,,HEAD,http://localhost:8000,HTTP/1.0,options_scenario,,200,,,http://localhost:8000,
http_req_sending,1623681406,0.519000,,,,true,,HEAD,http://localhost:8000,HTTP/1.0,options_scenario,,200,,,http://localhost:8000,
http_req_waiting,1623681406,6.351000,,,,true,,HEAD,http://localhost:8000,HTTP/1.0,options_scenario,,200,,,http://localhost:8000,
http_req_receiving,1623681406,0.034000,,,,true,,HEAD,http://localhost:8000,HTTP/1.0,options_scenario,,200,,,http://localhost:8000,
http_req_failed,1623681406,0.000000,,,,true,,HEAD,http://localhost:8000,HTTP/1.0,options_scenario,,200,,,http://localhost:8000,
checks,1623681406,1.000000,Expected response code for Request 1 is 200,,,,,,,,options_scenario,,,,,,
checks,1623681406,0.000000,Expected response code for Request 2 is 400,,,,,,,,options_scenario,,,,,,
data_sent,1623681406,334.000000,,,,,,,,,options_scenario,,,,,,
data_received,1623681406,849.000000,,,,,,,,,options_scenario,,,,,,
iteration_duration,1623681406,9.581895,,,,,,,,,options_scenario,,,,,,
iterations,1623681406,1.000000,,,,,,,,,options_scenario,,,,,,
