504s are not being logged properly with checks
I’m seeing some interesting behavior with the summary output and how it is logging data to present what it shows properly.
Below is a screenshot of the summary from one of my latest runs. I have two checks, then the default summary output from k6. I would also like to note that I am load testing a graphql endpoint.
The code for the checks is as follows:
check(res, {
    'response code was 200': (res) => res.status == 200,
// Need to check body of response for errors since this is a GQL endpoint
  check(body, {
    'body contains no errors': (body) => body.errors == undefined,
What alerted me to the issue was that the response code was 200 check is reporting that all of the requests are 200, but the http_req_failed metric is reporting that 128 requests failed.
On top of this, when I run a load test I sometimes get these errors to pop-up intermittently:
ERRO[0767] GoError: cannot parse json due to an error at line 1, character 2 , error: invalid character 'r' looking for beginning of value
        at reflect.methodValueCall (native)
        at file:///Users/zakirefai/Work/load-testing/dist/price-quotes.products.coordinates.unauth.test.js:2:24999(3)
        at c (file:///Users/zakirefai/Work/load-testing/dist/price-quotes.products.coordinates.unauth.test.js:2:25121(54))  executor=ramping-vus scenario=load source=stacktrace
After some investigation into the granular output from the test I believe I have found the issue. Here is the output of the http_req_failed when it encounters a failed request.
    "metric": "http_req_failed",
    "type": "Point",
    "data": {
        "time": "2024-04-24T11:07:00.264696-04:00",
        "value": 1,
        "tags": {
            "error_code": "1504",
            "expected_response": "false",
            "group": "",
            "method": "POST",
            "name": "https://api.prescryptive.io/graphql",
            "proto": "HTTP/2.0",
            "scenario": "load",
            "status": "504",
            "tls_version": "tls1.3",
            "url": "https://api.prescryptive.io/graphql"
It tells me that a 504 error occurred during one of the requests. Now the checks should fire off and log that a 504 error occurred, but nowhere after a 504 failure does the check occur. I can see the checks logging in the granular output after a 200 response, but not after a 504. I believe this is where the JSON error ERRO[0767] from above comes into play. Maybe it is failing to perform the check against this request because it’s not able to parse the JSON somehow after a 504?
Please advise on what I should do. I’m not sure how to go about solving this.
I think there is no way r.json() can succeed if the response status > 399 and is not JSON content
hence it’s a basic error of the method
maybe log something like r.body or better r.status_text instead of r.json()
@zakirefai
I think this happens because you call res.json() before the res.status == 200 check, and if the status is not 200, the body is not parsable as json.
You should modify your script like this:
check(res, {
if (res.status == 200) {
  const body = res.json();
  check(body, {
I hope this helps
Thanks! This small fix worked
