hello, help me please
First, you should select the metric column as ‘temperature’ - this will be your series name. Then looking at your data it seems kind of right since your time range don’t seem to include data points for 2018-01-28 to 2018-01-24. Please make sure that you look over bigger time range to see all your data points.
Under display tab you could change the draw modes as well from points to lines for example.
Marcus
thanks Mr. Marcus
Regard
Alvianno
