Hi, we would like to deploy Loki in Simple scalable deployment on-premise, with storage filesystem (shared by NFS). (3x read, 3x write). But i read in documentation that it Is really bad idea to use NFS.
What are advantages to use something like MinIO instead?
Did you make a conclusion ?
Now I met with the same dilemma
Cheers,
GT
We decided to use minio as backend. It is really easy to install and use.
So go for it
