I updated Grafana 6.5 to 6.7 , from that on status panel not working .
I tried to do some changes in the status panel config and it says
“Panel rendering error
Cannot read property ‘slice’ of undefined”
Do you mean this plugin? https://grafana.com/grafana/plugins/vonage-status-panel
That error maybe is due to the query not returning any data (is just a bad error message).
Might be worth opening an issue for the plugin here
Yeah sure, there is the open issue already in the plugin link you mentioned thanks
