Grafana 10.1.1
OS linux -
Each OAuth user will have their own org and when they log in, they will end up in their own org. -
I create an OAuth user and an org and put that user in their own org, using Grafana API.
I checked that the org is created and the OAuth user is only in that org.
When the OAuth user logs in, they will end up in their assigned org correctly (Grafana 10.0.3) -
What happened?
When the OAuth user logged in, they ended up in the default org (Grafana 10.1.1) -
The user should end up in their own assigned org. -
"environment": [
"name": "GF_AUTH_GENERIC_OAUTH_API_URL",
"value": "xxx"
"name": "GF_DATABASE_PASSWORD",
"value": "xxx"
"name": "GF_AUTH_GENERIC_OAUTH_TOKEN_URL",
"value": "xxx"
"name": "GF_AUTH_GENERIC_OAUTH_CLIENT_SECRET",
"value": "xxx"
"name": "GF_AUTH_SIGNOUT_REDIRECT_URL",
"value": "xxx"
"name": "GF_DATABASE_USER",
"value": "postgres"
"name": "GF_SMTP_USER",
"value": "xxx"
"name": "GF_AUTH_GENERIC_OAUTH_CLIENT_ID",
"value": "xxx"
"name": "GF_USERS_AUTO_ASSIGN_ORG_ID",
"value": "83"
"name": "GF_DATABASE_HOST",
"value": "xxx"
"name": "GF_AUTH_GENERIC_OAUTH_ENABLED",
"value": "true"
"name": "GF_SMTP_FROM_ADDRESS",
"value": "xxx"
"name": "GF_AUTH_GENERIC_OAUTH_SCOPES",
"value": "email profile aws.cognito.signin.user.admin openid"
"name": "GF_DATABASE_TYPE",
"value": "postgres"
"name": "GF_USERS_AUTO_ASSIGN_ORG",
"value": "true"
"name": "GF_AUTH_GENERIC_OAUTH_AUTH_URL",
"value": "xxx"
"name": "GF_AUTH_GENERIC_OAUTH_ALLOW_SIGN_UP",
"value": "true"
"name": "GF_SERVER_DOMAIN",
"value": "xxx"
"name": "GF_AUTH_GENERIC_OAUTH_ENABLED_NAME",
"value": "Cognito"
"name": "GF_SMTP_HOST",
"value": "xxx"
"name": "GF_AUTH_OAUTH_ALLOW_INSECURE_EMAIL_LOOKUP",
"value": "true"
"name": "GF_DATABASE_SSL_MODE",
"value": "disable"
"name": "GF_INSTALL_PLUGINS",
"value": "grafana-timestream-datasource"
"name": "GF_SMTP_PASSWORD",
"value": "xxx"
"name": "GF_SMTP_ENABLED",
"value": "true"
"name": "GF_SERVER_ROOT_URL",
"value": "xxx"
No -
No
Here is the story:
Grafana 10.0.3:
- I create an OAuth user
- I create an org
- I assign that user to that org
- OAuth user logs in and will be in its own org. This is the expected behavior
Grafana 10.1.1:
- I create an org
- OAuth user logs in and will be in the default org. This is not the expected behavior
