Hello dear Grafana community,
Im actually working on a react panel plugin wich is actually developed for Grafana >=7.0.0
Im using the “Cascader” component, wich allow me to select a query from the query list on left bottom side of the panel. like this:
The problem is the following : on panel load, my cascader component see all the existing queries, but when i create or delete a query, the cascader is not notified except if i click on the relad panel button
without using the reload button
After using the reload button
I already searched if it was possible to use an eventbus but i didnt found any solution.
when i add or remove a query, the context prop is not updated…
here is the code that generate the cascader options
(The component DisplayOptions is called in the customEditor component, context is passed as a prop)
export default function DisplayOptions({ context, dataBinding, onChangeBinding }: DisplayOptionsProps) {
const generateOptions = (): CascaderOption[] => {
return context.data.map((dataFrame: DataFrame) => ({
label: dataFrame.refId ?? 'Undefined query name',
value: dataFrame.refId ?? 'Undefined query name',
items: dataFrame.fields.map(({ name }) => ({
label: name,
value: `${dataFrame.refId ?? 'Undefined query name'}/${name}`,
All i need is a way to keep the cascader updated, without the need to click on the reload button each times i create / remove / edit a query.
thanks in advance for anyone who can help me ![]()
