The current setup (Grafana 10.1.1):
A prometheus alert, which has a custom label (alertname = test ).
Default notification policy, group by alertname.
Nested policy with label , alertname = test, Continue matching subsequent sibling nodes enabled.
Question:
How can I achieve to send notification to both the Nested and the deafult policy?
I think according to the Grafana Documentation I have the correct setup, but it seems I cannot have it notifing both parties.
It is usually just firing in the default policy and not going further to the nested one.
I cannot see what is wrong and I have tried multiple things, as removing the group by in default , setting 2 labels (alertname, alertname1) in the rule and having the default one , and the nested the other one, have used override grouping, basicaly almost every possible combination.
Thing is I can’t even make it to send the notification only to the nested one.
Any help would be appreciated.
