Noticed the threshold values are not calculated in recent tests while using same script earlier the values were populated
Earlier the test were marked as failed with threshold values populated which is not working currently with exact same script.
before -
now -
Hi @officetabsep2023
Welcome to the community forum :wave:
Thanks for reporting this.
Could you reach out to k6 support for this? The team will be able to look at your cloud tests and help out.
Cheers!
Hi @eveveebee,
Thanks for the info will reach out to k6 support.
Rgds,
Mohammed
Thank you for reporting this, @officetabsep2023. The k6 cloud team is already looking into it and if you reach out to support they can ask for any additional information if needed.
Cheers!
