Not showing Data in Grafana
Using this script in grafana in doesn’t show any data
SELECT DISTINCT
vs.volume_mount_point AS DiskDrive,
vs.total_bytes / 1024 / 1024 / 1024 AS Total_Size_GB,
vs.available_bytes / 1024 / 1024 / 1024 AS Free_Space_GB,
(vs.available_bytes * 100.0 / vs.total_bytes) AS Free_Space_Percentage,
GETDATE() AS time
FROM sys.master_files mf
CROSS APPLY sys.dm_os_volume_stats(mf.database_id, mf.file_id) vs;
Welcome @zedrix08
what do you see when you click Data View in grafana
What do you see when you run that SQL script outside of grafana
No Data showing in grafana using my script
But upon running my script in MS SQL there is a result
Try
Dateadd(hh,-2,getutcdate()) instead of
GETDATE()
Still No Data Result in Grafana Dashboard
Click on data view, what do you see. Post a screen shot
