Hi, I am trying to use postman-to-k6 to generate a K6 script however it failed with the error below. The xyz.js was not even generated.
It seems complaining a syntax error in the xyz.js (which is supposed to be the output of postman-to-k6).
I know the correct syntax is
config.options[“{{apiKeyHeader}}”] = ${pm[Var]("apiKey")};
How could I fix a syntax error in a *.js script that was never generated?
C:\Projects\Benstro>npx postman-to-k6 xyz.postman_collection.json -e xyz_ST.postman_environment.json -o xyz.js
Unexpected token (29:22)
27 | address: “{{txProcessorBase}}/health”,
28 | auth(config, Var) {
29 | config.options.{{apiKeyHeader}} =
30 | }
31 | })
32 |
