I am seeing some error logs with distributors with the v1.1.0-rc release. I see that all ingesters are active and in healthy state and there are no errors in ingester logs corresponding to this.
level=error ts=2021-08-23T10:46:10.157097875Z caller=log.go:27 msg=“pusher failed to consume trace data” err=“rpc error: code = Unavailable desc = transport is closing”
level=warn ts=2021-08-23T10:46:09.836463272Z caller=pool.go:185 msg=“removing distributor_pool failing healthcheck” addr=10.58.21.174:9095 reason=“rpc error: code = DeadlineExceeded desc = context deadline exceeded”
ts=2021-08-23T10:46:05.813528284Z caller=memberlist_logger.go:74 level=error msg=“Failed fallback ping: read tcp 10.58.14.31:42490->10.58.44.61:7946: i/o timeout”
level=warn ts=2021-08-23T10:46:02.153600971Z caller=pool.go:185 msg=“removing distributor_pool failing healthcheck” addr=10.58.26.235:9095 reason=“rpc error: code = DeadlineExceeded desc = context deadline exceeded”
level=error ts=2021-08-23T10:45:55.258558135Z caller=log.go:27 msg=“pusher failed to consume trace data” err=“rpc error: code = Unavailable desc = transport is closing”
level=warn ts=2021-08-23T10:45:55.048372224Z caller=pool.go:185 msg=“removing distributor_pool failing healthcheck” addr=10.58.26.41:9095 reason=“rpc error: code = DeadlineExceeded desc = context deadline exceeded”
level=error ts=2021-08-23T10:45:35.558405519Z caller=log.go:27 msg=“pusher failed to consume trace data” err=“rpc error: code = Unavailable desc = transport is closing”
