Hi all,
I’m testing the Grafana Cloud Agent on Kubernetes (K3s cluster). I installed the agent accourding to the Quickstart Guide, everything seems to be running on the cluster.
The agent seems to be working according to the logs and I see that in the stack page Prometheus shows 3084 active metrics as well.
However, if I go to Grafana Cloud it shows no metrics/series. I tried analyzing Prometheus metrics usage with Grafana Explore but it does not return any results.
If I query the api it does return metrics.
I must be doing something wrong, might be at the scraper but i followed the instructions on the quick start.
Any thoughts?
Thanks in advance.
