Kube-state-metrics and Grafana Agent run as binaries inside a container --> Grafana UI shows no kube-state-metrics metrics
    grafana-agent 0.27.1 on a Ubuntu Container image running on an EKS cluster.
    I am trying to receive KSM metrics in the Grafana Cloud Dashboards
    I have a Ubuntu container that runs a grafana-agent and KSM binaries.
    I configured them to collect data from the EKS cluster it runs in as a deployment and send to our Grafana cloud.
  • What happened?
    I see Kubelet and Cadvisor metrics but not the KSM ones
    I expect to see Kubelet/Cadvisor and KSM metrics in the dashboard
    This is the grafana-agent configuration:
server:
  log_level: debug
prometheus:
  global:
    scrape_interval: 60s
    external_labels:
      client_id: asdfsdfsdfsdfsdfsdfuw=
      client_name: pavel-client
      service_name: pavel-service
  configs:
  - name: integrations
    remote_write:
    - url: https://prometheus-prod-10-prod-us-central-0.grafana.net/api/prom/push
      basic_auth:
        username: 234234
        password: password
    scrape_configs:
    - bearer_token_file: /var/run/secrets/kubernetes.io/serviceaccount/token
      job_name: integrations/kubernetes/kube-state-metrics
      scrape_interval: 30s
      kubernetes_sd_configs:
          - role: pod
      metric_relabel_configs:
          - source_labels: [__name__]
            regex: kube_resourcequota|kube_node_info|kube_node_status_condition|kube_node_status_allocatable|kube_node_status_capacity|kube_node_spec_taint|kube_horizontalpodautoscaler_status_condition|kube_horizontalpodautoscaler_spec_min_replicas|kube_horizontalpodautoscaler_spec_max_replicas|kube_horizontalpodautoscaler_spec_target_metric|kube_horizontalpodautoscaler_status_current_replicas|kube_horizontalpodautoscaler_status_desired_replicas|kube_pod_info|kube_pod_owner|kube_pod_status_phase|kube_pod_container_info|kube_pod_container_resource_limits|kube_pod_container_resource_requests|kube_pod_container_status_waiting_reason|kube_pod_container_status_restarts_total|kube_deployment_status_replicas_updated|kube_deployment_spec_replicas|kube_deployment_status_replicas_available|kube_replicaset_owner|kube_replicaset_spec_replicas|kube_replicaset_status_ready_replicas|kube_job_owner|kube_job_status_active|kube_job_failed|kube_statefulset_status_observed_generation|kube_statefulset_status_replicas_updated|kube_statefulset_replicas|kube_statefulset_metadata_generation|kube_statefulset_status_current_revision|kube_statefulset_status_replicas_ready|kube_statefulset_status_replicas|kube_statefulset_status_update_revision|kube_daemonset_status_number_misscheduled|kube_daemonset_status_updated_number_scheduled|kube_daemonset_status_number_available|kube_daemonset_status_desired_number_scheduled|kube_daemonset_status_current_number_scheduled
            action: keep
      relabel_configs:
          - action: keep
            regex: kube-state-metrics
            source_labels:
              - __meta_kubernetes_pod_label_app_kubernetes_io_name
      job_name: integrations/kubernetes/cadvisor
          - role: node
            regex: container_network_receive_bytes_total|container_network_transmit_bytes_total|container_memory_rss|container_memory_working_set_bytes|container_cpu_usage_seconds_total|container_cpu_cfs_periods_total|container_cpu_cfs_throttled_periods_total
            action: keep
      relabel_configs:
          - replacement: kubernetes.default.svc.cluster.local:443
            target_label: __address__
          - regex: (.+)
            replacement: /api/v1/nodes/$1/proxy/metrics/cadvisor
            source_labels:
              - __meta_kubernetes_node_name
            target_label: __metrics_path__
      scheme: https
      tls_config:
          ca_file: /var/run/secrets/kubernetes.io/serviceaccount/ca.crt
          insecure_skip_verify: false
          server_name: kubernetes
      job_name: integrations/kubernetes/kubelet
          - role: node
            regex: kubelet_node_name|kubelet_node_config_error|kubelet_running_pods|kubelet_running_pod_count|kubelet_running_containers|kubelet_running_container_count|kubelet_volume_stats_inodes_used|kubelet_volume_stats_inodes|kubelet_volume_stats_available_bytes|kubelet_volume_stats_capacity_bytes
            action: keep
      relabel_configs:
          - regex: (.+)
            source_labels:
      scheme: https
      tls_config:
loki:
  configs:
  - name: default
    positions:
      filename: /tmp/positions.yaml
    scrape_configs:
      - job_name: some-logs
        static_configs:
          - targets: [localhost]
            labels:
              job: some-logs
              __path__: /var/log/somnething.log
              client_id: afdasdfasdasdf
    clients:
      - url: https://logs-prod-us-central1.grafana.net/api/prom/push
        basic_auth:
          username: 123123
          password: password
No errors or warnings pertaining the kube-state-metrics.
Running the following command I could see that KSM is scraping the data from the cluster successfully:
curl http://localhost:8080/metrics
Running curl http://0.0.0.0:80/agent/api/v1/metrics/targets | jq | grep job
I get the following response:
"job": "integrations/kubernetes/cadvisor"
"job": "integrations/kubernetes/kubelet"
I did not use the default Helm installation guidelines but rather broke them to several parts of our deployment
kube-state-metrics watches Kubernetes resources in your cluster and emits Prometheus metrics that can be scraped by Grafana Agent. To learn more, please see the kube-state-metrics docs.
The agent/integration config you posted is for the agent to scrape KSM, Cadvisor, and Kublet, these three need to be deployed in the cluster as well. The missing piece is deploying Kube-State-Metrics to your cluster.
Deploy kube-state-metrics
If you do not wish to use Helm to manage kube-state-metrics, you can use the example manifests in the kube-state-metrics repo.
For a helm install, run the following commands from your shell to install kube-state-metrics into the default namespace of your Kubernetes cluster:
helm repo add prometheus-community https://prometheus-community.github.io/helm-charts && helm repo update && helm install ksm prometheus-community/kube-state-metrics --set image.tag=v2.4.2 -n default
To deploy kube-state-metrics into a non-default Namespace, please change -n default to your desired Namespace.
Hi Petero, thank you for the brief response. I am running the ksm binary in the same container as the grafana agent. I believe I got all the configmaps and namespaces set correctly because I can see the ksm data running here:
cadvisor and kubelet data I see being sent successfully to Grafana UI. ksm does not…
Any way I can debug and understand what went wrong?
I don’t see any errors in the logs
Hey @pavelzagalsky
Happy to help work through the use case and config.
Please send in a note to cloud-success@grafana.com.
Thanks!
