No historical data avaiable after rollback 2.8.6 -> 2.8.4
Greetings
We’ve been using Loki for quite a while and running version 2.8.6. We received some feedback about Loki’s performance and especially about “occasional gaps in logs”. I’ve found this issue on Github that described what we are actually experiencing and lots of folks recommended rolling back to version 2.8.4 , reporting no issue reproduced there.
Well, we did it, since I thought going back on 2 patch versions in not a big deal and it appeared that in actually is. Our data in object store from the time before rollback is inaccessible now, Loki reports an error on them:
failed to get s3 object: NoSuchKey: The specified key does not exist. status code: 404
Did anyone have the same behaviour and how did you managed it? All data is in place in object store, but somehow Loki is unable to access it.
Our current setup is scalable two target mode (reader + writer) running in ECS Fargate.
Here is config file:
# General config
auth_enabled: ${AUTH_ENABLED:-true}
shutdown_delay: 30s
# Server config
server:
  http_listen_address: 0.0.0.0
  http_listen_port: ${HTTP_LISTEN_PORT:-3100}
  http_server_idle_timeout: 120s
  http_server_read_timeout: 3m
  http_server_write_timeout: 3m
  grpc_listen_address: 0.0.0.0
  grpc_listen_port: ${GRPC_LISTEN_PORT:-9096}
  grpc_server_max_recv_msg_size: 20971520 # 20mb
  grpc_server_max_send_msg_size: 20971520 # 20mb
  grpc_server_max_connection_idle: 120s
  grpc_server_max_connection_age: 1h
  grpc_server_max_connection_age_grace: 120s
  grpc_server_keepalive_time: 10m
  graceful_shutdown_timeout: 10s
  log_level: "${LOG_LEVEL:-info}"
  log_source_ips_enabled: true
# Distributor config
distributor:
  ring:
    kvstore:
      store: memberlist
    heartbeat_period: 5s
    heartbeat_timeout: 30s
    instance_interface_names:
      - eth1
  rate_store:
    max_request_parallelism: 200
    stream_rate_update_interval: 1s
    ingester_request_timeout: 1s
# Querier config
querier:
  max_concurrent: 8
  query_ingesters_within: 5m
  engine:
    timeout: 5m0s
    max_look_back_period: 1m
  query_store_only: false
  multi_tenant_queries_enabled: true
# Query-scheduler config
query_scheduler:
  max_outstanding_requests_per_tenant: 100
  querier_forget_delay: 0s
  use_scheduler_ring: false
# Frontend config
frontend:
  address: ${LOKI_BIND_ADDR:-0.0.0.0}
  scheduler_address: ${LOKI_READER_DNS:-loki-reader.cluster.internal}:${GRPC_LISTEN_PORT:-9096}
  scheduler_dns_lookup_period: 10s
  scheduler_worker_concurrency: 5
    - eth1
  log_queries_longer_than: 0
  query_stats_enabled: false
  compress_responses: true
# Query-range config
query_range:
  align_queries_with_step: true
  cache_results: true
  max_retries: 5
  results_cache:
    compression: snappy
    cache:
      default_validity: 12h
      memcached:
        expiration: 600s
        batch_size: 512
      memcached_client:
        addresses: ${MEMCACHED_SERVER_URL:-localhost:11211}
        timeout: 500ms
# Ruler config
ruler:
  enable_api: false
  alertmanager_url: ${VM_ALERTMANAGER_URL:-alertmanager.cluster.internal:9999}
  enable_alertmanager_discovery: false
  alertmanager_refresh_interval: 1m0s
  enable_alertmanager_v2: false
  notification_queue_capacity: 10000
  notification_timeout: 10s
  for_outage_tolerance: 1h0m0s
  for_grace_period: 10m0s
  resend_delay: 1m0s
  wal:
    dir: /tmp/ruler-wal
  storage:
    type: s3
    s3:
      bucketnames: ${S3_BUCKET_NAME:-loki-store}
      region: ${S3_BUCKET_REGION:-eu-central-1}
  rule_path: /tmp/prom-rules
  remote_write:
    enabled: false
    clients:
      vm:
        url: ${VM_RW_URL:-vm.cluster.internal:9999}
    config_refresh_period: 10s
# Ingester client config
ingester_client:
  pool_config:
    client_cleanup_period: 15s
    health_check_ingesters: true
    remote_timeout: 5s
  remote_timeout: 5s
# Ingester config
ingester:
  lifecycler:
    ring:
      kvstore:
        store: memberlist
      heartbeat_timeout: 10s
      replication_factor: 3
    join_after: 0s
    min_ready_duration: 15s
    final_sleep: 3s
    observe_period: 5s
    unregister_on_shutdown: true
    readiness_check_ring_health: false
  max_transfer_retries: 0
  concurrent_flushes: 32
  flush_check_period: 10s
  flush_op_timeout: 1m
  chunk_retain_period: 1m
  chunk_idle_period: 5m
  chunk_block_size: 262144 # 256kb
  chunk_target_size: 15728640 # 15mb
  chunk_encoding: snappy
  max_chunk_age: 2h
  autoforget_unhealthy: true
  max_returned_stream_errors: 10
  query_store_max_look_back_period: 0s
  wal:
    enabled: true
    dir: /tmp/ingester-wal
    checkpoint_duration: 1m
    flush_on_shutdown: true
    replay_memory_ceiling: 50MB
  index_shards: 32
  max_dropped_streams: 10
# Index gateway config
index_gateway:
  mode: ring
  ring:
    kvstore:
      store: memberlist
      - eth1
    instance_addr: ${LOKI_BIND_ADDR:-0.0.0.0}
    instance_port: ${GRPC_LISTEN_PORT:-9096}
# Storage config
storage_config:
  aws:
    http_config:
      idle_conn_timeout: 3m
      response_header_timeout: 10s
    signature_version: v4
    storage_class: STANDARD
  index_cache_validity: 5m0s
  index_queries_cache_config:
    memcached:
      expiration: 600s
      batch_size: 512
    memcached_client:
      timeout: 500ms
  disable_broad_index_queries: false
  max_parallel_get_chunk: 150
  max_chunk_batch_size: 50
  boltdb_shipper:
    active_index_directory: /tmp/boltdb-shipper-active
    shared_store: s3
    shared_store_key_prefix: index/
    cache_location: /tmp/boltdb-shipper-cache
    cache_ttl: 1h
    resync_interval: 5m
    index_gateway_client:
      server_address: ${LOKI_READER_DNS:-loki-reader.cluster.internal}:${GRPC_LISTEN_PORT:-9096}
    build_per_tenant_index: true
  tsdb_shipper:
    active_index_directory: /tmp/tsdb-index
    shared_store: s3
    shared_store_key_prefix: tsdb-index/
    cache_location: /tmp/tsdb-cache
    cache_ttl: 1h
    resync_interval: 5m
# Chunk store config
chunk_store_config:
  chunk_cache_config:
    memcached:
      expiration: 600s
      batch_size: 512
    memcached_client:
      timeout: 500ms
  write_dedupe_cache_config:
    memcached:
      expiration: 600s
      batch_size: 512
    memcached_client:
      timeout: 500ms
  cache_lookups_older_than: 1s
# Period schema config
schema_config:
  configs:
    store: boltdb-shipper
    object_store: s3
    schema: v12
    index:
      prefix: loki_index_
      period: 24h
    chunks:
      prefix: loki_chunks_
      period: 24h
    row_shards: 16
  # New TSDB schema below
    store: tsdb
    object_store: s3
    schema: v12
    index:
      prefix: loki_index_
      period: 24h
    chunks:
      period: 24h
    row_shards: 16
# Compactor config
compactor:
  working_directory: /tmp/compactor
  shared_store: s3
  shared_store_key_prefix: compactor-index/
  compaction_interval: 10m
  apply_retention_interval: 60m
  retention_enabled: false
  retention_delete_delay: 2h
  retention_delete_worker_count: 150
  retention_table_timeout: 0s
  delete_batch_size: 70
  delete_request_cancel_period: 24h0m0s
  delete_max_interval: 0s
  max_compaction_parallelism: 1
  upload_parallelism: 10
  compactor_ring:
    instance_id: "${HOSTNAME}"
      - eth1
# Limits config
limits_config:
  ingestion_rate_strategy: local
  ingestion_rate_mb: 100
  ingestion_burst_size_mb: 150
  max_label_name_length: 512
  max_label_value_length: 2048
  max_label_names_per_series: 24
  reject_old_samples: true
  reject_old_samples_max_age: 1w
  creation_grace_period: 30m
  enforce_metric_name: true
  max_line_size: 0
  max_line_size_truncate: false
  increment_duplicate_timestamp: false
  max_streams_per_user: 0
  max_global_streams_per_user: 0
  unordered_writes: true
  per_stream_rate_limit: 50MB
  per_stream_rate_limit_burst: 75MB
  max_chunks_per_query: 2000000
  max_query_series: 5000
  max_query_lookback: 0s
  max_query_length: 100d
  max_query_parallelism: 32
  tsdb_max_query_parallelism: 512
  cardinality_limit: 100000
  max_streams_matchers_per_query: 1000
  max_concurrent_tail_requests: 10
  max_entries_limit_per_query: 5000
  max_cache_freshness_per_query: 1m
  max_queriers_per_tenant: 0
  query_timeout: 180s
  split_queries_by_interval: 30m
  min_sharding_lookback: 0s
  retention_period: 370d
# Frontend worker config
frontend_worker:
  dns_lookup_duration: 10s
  parallelism: 20
  match_max_concurrent: true
# Other config
tracing:
  enabled: false
analytics:
  reporting_enabled: false
# Memberlist settings
memberlist:
  node_name: "${HOSTNAME}"
  randomize_node_name: true
  retransmit_factor: 3
  pull_push_interval: 10s
  gossip_interval: 200ms
  gossip_to_dead_nodes_time: 10s
  dead_node_reclaim_time: 15s
  compression_enabled: true
  join_members:
    - dns+${LOKI_READER_DNS:-loki-reader.cluster.internal}:${LOKI_CLUSTER_LISTEN_PORT:-7946}
    - dns+${LOKI_WRITER_DNS:-loki-writer.cluster.internal}:${LOKI_CLUSTER_LISTEN_PORT:-7946}
  min_join_backoff: 1s
  max_join_backoff: 1m
  max_join_retries: 10
  abort_if_cluster_join_fails: true
  left_ingesters_timeout: 30s
  leave_timeout: 10s
  bind_addr:
   - ${LOKI_BIND_ADDR:-0.0.0.0}
  bind_port: ${LOKI_CLUSTER_LISTEN_PORT:-7946}
# Common config
common:
  storage:
    s3:
  persist_tokens: false
  ring:
    kvstore:
      store: memberlist
      - eth1
    - eth1
  compactor_address: http://${LOKI_READER_DNS:-loki-reader.cluster.internal}:${HTTP_LISTEN_PORT:-3100}
  compactor_grpc_address: ${LOKI_READER_DNS:-loki-reader.cluster.internal}:${GRPC_LISTEN_PORT:-9096}
Big kudos to Community Forum moderation, this post is finally available after being in review for month.
For all who might read it, I actually managed to find source of issue by myself.
I made a mistake while edited schema_config, by incrementing schema version for my existing schema, instead of adding it as new one with activation date. Was not that obvious for me at that moment.
So I’ve managed to mitigate impact from this mistake by restoring previous value of schema version and adding a proper entry in schema config. Part of data left being inaccessible because that day schema rolled over in the middle of the day, but that is not that critical for me.
