New Grafana Install - No Plugins loading
    • Grafana v12.3.0 (20051fb1fc)
    • Windows 11 Enterprise
    • Installing Grafana on a local Windows Machine
    • Downloaded windows11.msi file and ran install
  • What happened?
    • It installed without issue, but when running the console gives errors about the plugins not loading
    • Pluggins to load - Especially the PostgreSQL pluggin which it says is installed and is a core pluggin.
    • When trying to create a data source with the PostgreSQL plugin the UI says the grafana-postgres-datasource failed
    • The console has two basic errors repeated many times
:3000/connections/datasources:1 Not allowed to load local resource: file:///C:/Program%20Files/GrafanaLabs/grafana/public/app/plugins/datasource/grafana-postgresql-datasource/dist
:3000/c:/Program%20Files/GrafanaLabs/grafana/data/plugins/grafana-exploretraces-app.js?_cache=1763661549333:1  Failed to load resource: the server responded with a status of 404 (Not Found)
hook.js:608 Error: Could not load plugin
    at importPluginModule.ts:70:17
    at async _n (pluginImporter.ts:94:25)
    at async cn (pluginPreloader.ts:43:5)
    at async Promise.all (:3000/index 0)
    at async Vt (pluginPreloader.ts:35:3)Caused by: Error: 404 Not Found, loading http://127.0.0.1:3000/c:/Program Files/GrafanaLabs/grafana/data/plugins/grafana-exploretraces-app.js?_cache=1763661549333 (SystemJS Error#7 https://github.com/systemjs/systemjs/blob/main/docs/errors.md#7)
    at system.js:706:15
I’ve searched and tried every resource that is available to figure this out. No luck so far.
I had the same issue and found the same error. If you look at the folder structure it seems there is defect forming the path to the plugin.
I meet this issue too, seems it’s combinning a incorrect plugin path like “{url}”+“{abs path}”
http://1.2.3.4:1234/X:/Telemetry/GrafanaLabs/grafana/data/plugins/
Converted this post to a issue: New Grafana 12.3.0 Install - No Plugins loading · Issue #114279 · grafana/grafana · GitHub
do you know if the problem is only related to the installer package .MSI or it is also the problem still using zip files grafana-enterprise_12.3.0_19497075765_windows_amd64.tar.gz?
