V8.3.4 -
Creating an alert to slack -
Following this url - What happened?
I got an alert but not with the value of the graph - What did you expect to happen?
An alert with the (temperature) value of the graph - Can you copy/paste the configuration(s) that you are having problems with?
N/A - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
N/A - Did you follow any online instructions? If so, what is the URL?
See above
Hello
and welcome to the forum, @erikoffereins
there are some gotchas when it comes to alert templating. What datasource is generating the alerts, and is the alert a multi-dimensional alert or a traditional alert?
We are using InfluxDB as datasource and now we use the multi-dimensional alert instead of the traditional.
I’m trying to understand the way of making custom templates but I am still not a pro in it
What we want is a template for a single alert (otherwise the firing and resolved will be merged). And we also want to customize the header of the message.
Is that possible?
