MySQL timezone conversion: interval Europe/Paris failed
Hello, for my panel i need to transform my time into an other time zone,
in previous panel i used
but in France UTC+2 became UTC+1 in december, so i cant just use UTC+2
I use a mysql datasource
i use the line under :
UNIX_TIMESTAMP(CONVERT_TZ(timestamp,‘Europe/Paris’, ‘UTC’)) * 1000 AS time,
But Grafana or sql don’t recognize ‘Europe/Paris’ interval
i already try with ’ with ` and with nothing before and after Europe/Paris
Is anyone know this issue and how i can fix that
Thanks you
The error interpolation failed: error parsing interval 'Europe/Paris' which most likely means your MySQL/MariaDB timezone tables are not loaded.
Check:
sql
SELECT COUNT(*) FROM mysql.time_zone_name WHERE Name = 'Europe/Paris';
Returns 1 → tables already loaded, share your full query for further help
Returns 0 → run Step 2
Load timezone tables:
bash
mysql_tzinfo_to_sql /usr/share/zoneinfo | mysql -u root -p mysql
After loading, your original query will work correctly and Europe/Paris handles DST automatically → no need to hardcode UTC+2 or UTC+1.
its look like i have the table
But still the error
So here my query :
SELECT
UNIX_TIMESTAMP(CONVERT_TZ(timestamp, ‘Europe/Paris’, ‘UTC’)) * 1000 AS time,
SUM(V_temps_P1) AS P1,
SUM(V_temps_P2) AS P2
FROM
plcnext.opcua
WHERE
$__timeFilter(CONVERT_TZ(timestamp, ‘Europe/Paris’, ‘UTC’))
AND (
V_temps_P1 IS NOT NULL
OR V_temps_P2 IS NOT NULL
GROUP BY
$__timeGroup(
CONVERT_TZ(timestamp, 'Europe/Paris', 'UTC'),
'1h'
ORDER BY
$__timeGroup(
'1h'
Since named time zones like Europe/Paris are supported by MySQL/MariaDB when the time zone tables are loaded, I’d try removing CONVERT_TZ() from the Grafana macros first and only use it in the SELECT clause:
SELECT
  UNIX_TIMESTAMP(CONVERT_TZ(timestamp, 'Europe/Paris', 'UTC')) * 1000 AS time,
FROM plcnext.opcua
WHERE
  $__timeFilter(timestamp)
  AND (
GROUP BY
  $__timeGroup(timestamp, '1h')
ORDER BY
  $__timeGroup(timestamp, '1h');
Could you also tell whether the timestamp column is stored in UTC or Europe/Paris local time?
It work
However i still have 2 problems
1st : I don’t see anymore the hours (left is with convert_tz +02:00 +00:00) (right is what you give me)
2nd value are not good anymore, the left one have the good value (i look in my DB) but the right one have other and incorect value
