MySQL query efficiency
    v9.2.2
    Create Time series Panel with data in MySQL having indexed time column and filtering on small time interval
    indexed time column and filtering on small time interval - but needs long time to respond
    using additional view on same data with filter on one day - resond is much more faster
    similar access via SQL filter via Excel on same db responds within 2 seconds, so very fast
  • What happened?
    long time needed to get data view
    to be faster, similar as excel
    one db with 2 mio data rows and 63 columns, indexed on timestamp-column
    Timeseries is created with:
    SELECT time,PVPower,Gridpower,Battpower FROM db ODER BY time ASC
    no
I have 2 millions records on 63 column, usually one record every 5 seconds.
I am using
to fetch the data for display, and using filter within grafana to show last 6 hours.
Respond time is approximately 40 sec.
I do the exact same within excel, using a connection to the MySQL-Server and adding the filter to the sql
SELECT * FROM db WHERE time BETWEEN “2022-10-28 00:00:00” AND “2022-10-29 00:00:00”;
which responds with the data within 2 seconds.
Right now i am using the trick to have an additional view in MySQL which filters the amount of data to the last day only, which speeds up the respond but is not what i prefer… as this would disable and view on older data in the same panel.
Also i can use a
WHERE time BETWEEN “2022-10-30 00:00:00” AND “2022-10-31 00:00:00”
in the sql statement which will also speed up the respond. My assumption would have been that grafana is doing exactly this kind of where-clause to fetch the data?
So what am i doing wrong… shouldn’t the amount of data transferred and the process of selecting data be the same as i do with excel?
Maybe i am missing a trick here, how to connect more sophisticated to the mysql-db… any hint would be very much appreciated.
Grafana does not automagically filter your data. You need a WHERE clause with $timefilter.
Check out the documentation for $timeFilter
I did read this
and therefore did try with
SELECT time,PVPower,Gridpower,Battpower FROM db WHERE $__timeFilter ODER BY time ASC
i did also check with $timeFilter… nosuccess.
In both cases i get
db query error: Error 1054: Unknown column ‘$__timeFilter’ in ‘where clause’
The expression
SELECT time,PVPower,Gridpower,Battpower FROM db $__timeFilter ODER BY time ASC
shows a result… but not an improved response time…
Got It !!!
You have moved my search into the right direction.
The syntax seems to be
SELECT time,PVPower,Gridpower,Battpower FROM db WHERE $__timeFilter(time) ODER BY time ASC
This speeds up things
